Add watermark to file
716
8
07-26-2023 02:33 PM
RHammers
New Contributor III
Is it possible to have a watermark added when a .jpeg is submitted through a File question?
DougBrowning
MVP Esteemed Contributor
Well bummer looks like it was never added for exsisting images.  This is in the post I linked to above  https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-photo-watermarks/b...
  • You can apply text and image watermarks to new photos taken with the Survey123 field app camera. Watermarks cannot be applied to existing photos on the device.
DougBrowning
Yes this post has all the info  https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-photo-watermarks/b...
But note if the crew makes a mistake it is there forever. Hope that helps
RHammers
New Contributor III
Hi Doug,
Thanks for the reply. It seems this only works when Type is set to image. I need the watermark to be applied to a pre-existing image file that the users is selecting manually. See below.
DougBrowning
You can use image and browse to a file if you add this setting (this is new it used to do both).  You can have both options or force the user one way or the other.
In the column body::esri:style set it to  method=camera,browse  and see if that does it.
RHammers
New Contributor III
Hi Doug, thanks for the info. I have tried using your suggestion, however it still does not work and no watermark is applied. Any further suggestions?
DougBrowning
Did you change to image type also?  Screen shot what you have now
RHammers
New Contributor III
Yes I changed it to type image. See screenshot below. I hid some columns that had null values.
DougBrowning
RHammers
New Contributor III
Got it. Thanks again for the info!
