Accessing Data From Multiple Map questions
874
04-29-2022 05:56 PM
ColinCham
I am new to Survey123 and created a survey using the web app. For the purposes of my survey, I wanted to collect multiple location based data points from each respondent. I didn't realize that on Survey123 I could only have one map question.
I have already received several replies. Even though the respondents filled out multiple map questions, I can only see the GIS data from one of the questions. I was wondering if there was a way I could access the data from the other map questions, and if not if there was a way to have multiple map questions on the web app.
abureaux
MVP Frequent Contributor
I don't think you can grab this data after the fact. Here is a similar question with an answer:
