Add validation by page option to Survey123
7538
13
11-20-2019 08:13 AM
Status: Open
DougBrowning
MVP Esteemed Contributor
I would like the option to have the survey validate fields by page.  This way a user can not get to page 2 until page 1 is correct.
My issue is that a user will skip the line number of page 1 (even though it is required).  Then on page 2 they fill out repeats that inherit the line number from page 1.  When they skip on page 1 all my line numbers in the repeat are blank.  When submitting the user then adds a line number, which makes the repeats orphaned.
Most form programs will not let you go on to page 2 if page 1 is not valid.  I cannot just hide the rest of the form due to the size causing memory issues.
thanks!
13 Comments
CDFWR3Fisheries
I also need this fix on constraints, please ESRI.
DougBrowning
On critical fields using Red Notes as warnings or Emojis has helped.   Does not stop them but it helps a lot.
See my how to here
https://community.esri.com/t5/arcgis-survey123-documents/how-to-simulate-instant-data-checking-using...
chill_gis_dude
This seems like a no brainer!
