hello everyone! I have a problem with my story map ... I see it in my profile but it doesn't load anymore, the error is "there seems to be an issue..the story can't be loaded..why? can you help me? thanks
				Solved! Go to Solution.
@taniamassa -- I'm sorry you aren't able to load one of your stories. For a specific issue like this the best way to get help is to contact Esri Tech Support.
Hi @taniamassa ,
There could various reasons that the storymap will not load, may be some of the contents are not shared correctly, could be there are items missing which were originally used to create the storymap. There could be network connectivity issues.
What I would do is try to load the storymap in the browser and open Developer tools and investigate the network requests. (Most commonly 'F12' key would open that)
If you notice that there are some pending or blocked requests it might give you some pointers to look for.
Hope this helps.
I Have the same problem. After working in a story map for two weeks, finalizing it, I made an edit adding a picture, it seems it didn't work, but then I got that same message: "hmm...there seems to be an issue", the F12 shows me that there is an error and two warnings in the console view and in Open Issues to view: 1 page error. I don't know how to solve this. I can see my Story Map in draft mode in my stories.
