Sharing levels within a group
951
09-06-2023 09:25 AM
LEllis
I am trying to set up groups for classes where students can create a storymap, share it to the group, and then set the sharing level so it is only available for the group creator and a select few students. I do not want all the students to be able to view each other's work. Or if it is not possible to select sharing level to a few other students in the same group, can it be done where the storymap is shared between the group creator and the group member ONLY?
OwenGeo
Esri Notable Contributor
There aren't any additional levels of organization you can implement inside a group. You might want to check with the ArcGIS Online questions board to be sure, but I think to do what you are describing you'll need to make a separate ArcGIS Online group for each student group and add yourself to all those groups so you can see all the content shared to those groups.
Owen Evans
OwenGeo
Owen Evans
