Install Silently Documentation
1171
8
10-30-2024 08:41 PM
Status: Implemented
EdenPunter
It would be great to have documentation for installing ArcGIS Reality Studio silently.
Currently it looks like it doesn't exist - Install and authorize ArcGIS Reality Studio | ArcGIS Reality Studio Help (esri.com)
If supported, it would be great to include a portal_url parameter to set the default ArcGIS Enterprise/Online connection.
8 Comments
NicholasEverdell
Aligning the level of documentation across the new applications to the standard set by ArcGIS Pro would be fantastic!
Our organisation actively avoids any application that doesn't have silent install documentation.
BrendaButton
@EdenPunter , you're really speaking my language now. I have spent a solid amount of my company's time trying to run this through cmd and have had no luck. Not all of us can just sit around and watch loading bars.
FelixRohrbach
@EdenPunter : Thanks for this feedback! We continuously try to improve our documentation and it is valuable to know what information we are still lacking.
ArcGIS Reality Studio uses the same installer packaging as ArcGIS Pro. The following documentation should therefore also enable to install Reality Studio silently and add portals: Install ArcGIS Pro silently—ArcGIS Pro | Documentation
Personally, I have managed to use this documentation to create a Powershell script that installs Reality Studio automatically, but have not tried the more customized parameter.
Hopefully this already provides you all the required installation functionality - best case we would only need to include this information in the Reality Studio documentation.
EdenPunter
@FelixRohrbach
Thanks - that's good to know and makes sense. In that case, I believe it would be worthwhile to have a "Silent Install" doco page that has that information to avoid any confusion/ambiguity.
Otherwise, thanks for clarifying.
FelixRohrbach
While we would expect the ArcGIS Pro documentation to apply for Reality Studio as well, I added a ticket to the backlog with the scope of testing the functionality and updating the documentation accordingly.
FelixRohrbach
@EdenPunter the in-depth documentation is still pending. In the meantime though, this article by my colleague could be helpful as it describes the most common tasks to execute from the command line: Install and authorize ArcGIS Reality Studio automa... - Esri Community
DVargas
Good morning @EdenPunter ,
On top of the article that @FelixRohrbach shared, I'm happy to show you the in-depth documentation being available here: Install and authorize Reality Studio silently | ArcGIS Reality Studio Help
Thanks!
FelixRohrbach
