Install and authorize ArcGIS Reality Studio automatically
449
07-30-2025 11:09 PM
LeylaKern
In this article, you will learn how to quickly deploy ArcGIS Reality Studio to multiple machines by automating installation and license authorization.
All you need is the ArcGIS Reality Studio installer (.msi) and a valid authorization file (.prvc).
Setting up a basic automatic installation
Use the following commands to install and authorize Reality Studio. Remember to replace <Path_to_ArcGISRealityStudio.msi> and <Path_to_prvc> with the actual paths to the installer and authorization files.
Installation
msiexec.exe /i <Path_to_ArcGISRealityStudio.msi> ALLUSERS=1 INSTALLDIR="C:\Program Files\ArcGIS\RealityStudio" ACCEPTEULA=YES AUTHORIZATION_TYPE=SINGLE_USE /qb
Note that Reality Studio can only be used with a single-use license.
Authorization
"<ArcGIS_Reality_Studio_installation_directory>\bin\SoftwareAuthorizationPro.exe" /LIF "<Path_to_prvc>" /s
Note that the ArcGIS licensing service (SoftwareAuthorizationPro.exe) is only installed with Reality Studio for per-machine installations. For per-user installations, it can be installed with the following command:
msiexec.exe /i "<ArcGIS_Reality_Studio_installation_directory>\Resources\ArcGIS Licensing Service\ArcGISLS.msi" /qb
Customize your installation
To tailor your Reality Studio setup to your specific needs, the installation process can be executed with various arguments.
Parameter
and default value
Example
/i
Install a program
msiexec.exe /i <path/to/msi-file.msi>
/x
Uninstall a program
msiexec.exe /x {product-code}
/qb, /qr, /qn
Sets the user interface mode. Provides a basic (qb), reduced (qr) or no interface (qn)
msiexec.exe <path/to/msi-file.msi> /qb
ALLUSERS=2
Defines whether the software will be installed per machine, if set to 1, or per user, when set to 2
msiexec.exe /i <path/to/msi-file.msi> ALLUSERS=1
ENABLEEUEI=1
Contribute to the Esri User Experience Improvement program by setting this parameter to 1 or set to 0 to prevent participation
msiexec.exe /i <path/to/msi-file.msi> ENABLEEUEI=1
ENABLE_ERROR_REPORTS=1
Send error reports to Esri. Set to 0 to not send reports
msiexec.exe /i <path/to/msi-file.msi> ENABLE_ERROR_REPORTS=1
ACCEPTEULA=NO
Set to YES to accept the End User License Agreement (required for installation)
msiexec.exe /i <path/to/msi-file.msi> ACCEPTEULA=YES
INSTALLDIR
Default for per-machine installation:
%System Drive%\
Program Files\
For per-user installation:
%System Drive%\
%USERPROFILE%\
AppData\Local\Programs\
Specify where to install the software.
msiexec.exe /i <path/to/msi-file.msi> INSTALLDIR=<path/to/install/dir>
AUTHORIZATION_TYPE
Set the type of authorization. It is required to be SINGLE_USE for Reality Studio
msiexec.exe /i <path/to/msi-file.msi> AUTHORIZATION_TYPE=SINGLE_USE
Optional further installations
In addition to the standard installation, you can enhance your setup by installing supplementary coordinate system data and raster data. This can be accomplished through the ArcGIS Coordinate Systems Data and the ArcGIS Raster Data software components.
Coordinate System Data
The installation file (ArcGIS_Coordinate_Systems_Data_Windows_<release_part#>) can be obtained from My Esri and needs to be extracted on the machine where Reality Studio is installed.
The installation can then be started as follows:
msiexec.exe /i "<Coordinates_System_Data_Directory>\SetupFiles\CSD.msi" ACCEPTEULA=1 /qb
Raster Data
The installation file for the Raster Data (ArcGIS_Raster_Data_Windows_<release_part#>) can be downloaded and installed analogously as for the Coordinate System Data. Once extracted, the installation can be performed with the following command:
msiexec.exe /i "<Raster_Data_Directory>\SetupFiles\RasterData.msi" ACCEPTEULA=1 /qb
More details can be found in the documentation of the Coordinate System Data and the Raster Data.
Uninstalling software
To remove the software, execute the following command:
msiexec.exe /x {product code} /qb
The product code can be found in the Windows Registry Editor:
  • For per-machine installation: HKEY_LOCAL_MACHINE\SOFTWARE\Esri
  • For per-user installation: HKEY_CURRENT_USER\SOFTWARE\Esri
Summary
By utilizing the automatic installation process of ArcGIS Reality Studio, you can significantly improve the efficiency and reliability of your software installations. Customizing your setup further ensures that it aligns with your specific needs, providing you with a tailored solution that minimizes errors and saves time.
Contributors
