Please consider adding Ortho Mapping into ArcGIS Reality for ArcGIS Pro
Hi all, my team would like to use ortho mapping to produce traditional ortho. Currently, this can only be done using Pro Advanced. However, due to budget constraints, the team ask whether an extensions is available for Pro Standard? (I.e. mosaic dataset + ortho mapping). This could be done by adding it to: Pro Standard +…
Measurements that show within the 2D orthoimagery map.
I need to see if there can be on-the-fly measurements taken from the imagery data once it has been processed. We are coordinating with a project team on the data collected for a wastewater treatment plant and the Project manager needs the capability to see the real-time measurements as he draws them to coordinate…
Grouping projects in Site Scan
Create a system for organizing projects using tags or categories in Site Scan.
New Update: ArcGIS_RealityStudio_202612_201918
Since the new update i cannot see project nodes or whats being processed in the main window. but the engine is saying things are processing
TOP generation with Lidar takes a lot of time
Hi, When using Lidar data within a Reconstruction the "Analysis task" takes a huge amount of time. Sometimes more than 5 days, without seemingly making any progress until it suddenly finishes. I think there might be some problem or bug, when reading the lidar data. Our Lidar datasets are quite large (up to several billions…
16bit Pipeline in RealityStudios enhancement
At the moment RealityStudios produces new 16bit mrf's for every Reconstruction. Which is not manageable (disk space and time) for big projects. In the future we would greatly benefit from the possibility to re-use already converted 16-bit MRFs in subsequent reconstructions, thus avoiding the duplication of large datasets…
Elevation layers published to AGOL use meters instead of feet.
I've been publishing elevation data to AGOL without issues up until a couple days ago. Now all my elevation layers are being transformed from feet to meters, but still use the feet values. So what should be 4500 feet is coming in as 14600. I've replicated this from Site Scan, drone2map, and ArcGIS Pro. Seems to be a bug…
Drone2Map does not utilize GPU
I am using the latest build of Drone2Map (v1.3.1) on Windows 10 (1803) x64 with the following hardware: - Dell Precision 5820 - Intel Xeon W-2104 3.2GHz, 4C, 8.25M Cache - 32 GB RAM - 1024 GB SSD - NVIDIA® Quadro® P4000, 8GB, 4 DP I have checked the "Use CUDA" option and and set the "CPU Threads" to the max. I am trying to…
Know your data - Validating a camera session in ArcGIS Reality Studio
Have you ever struggled to get reliable results from your Reality Mapping projects? In many of the support cases we see, the root cause is not the imagery itself but how the data was added to the project. Often it comes down to a misinterpreted sensor parameter or incorrect orientation information set when the camera…
Mission Area/Boundary
The Mission Area sets automatically to the maximun boundary of the area in flight (white). The boundary should be possible to be set at an maximum outside perimiter of actual photos (red line).
Gaussian Splat Projection Tool
I've been experimenting with Gaussian Splats from Reality Extension and Drone2Map and noticed that the Project tool in ArcGIS Pro doesn't currently support Gaussian Splat outputs (3d_tiles or 3tz). I've put together the following tool to project a Gaussian Splat in 3D Tile format from one coordinate system to another using…
Spectral indices fall outside the normal range
Hi everyone, I'm a beginner in GIS and remote sensing, and I'm currently using ArcGIS Pro to calculate NDVI from Landsat imagery. However, I'm having a problem with the NDVI calculation. I first convert the DN values to surface reflectance using the formula: Reflectance = DN × 0.0000275 − 0.2 Then, I calculate NDVI using…
LICENSE ACTIVATION
YOUR SUPPORT FOR LICENSE ACTIVATION
Hi from Rana
Hello everyone! I’m interested in hearing from other YPN members about how we can make the GIS community more engaging and valuable for young professionals. GIS is evolving rapidly, with technologies such as AI, remote sensing, web GIS, and spatial data science creating new opportunities. At the same time, many students…
Moving a Project to a new PC
Hi I have moved one of my projects onto a new PC, how do i go about changing project paths for the images and anything else i need to change? Regards Ryan
Symbology widths of lines and polygons in Site Scan
It would be nice to be able to edit the line with of the lines and polylines down to 0.01 ft so the lines don't hide the things that are being identified or highlighted by the shapes.
Polygon List for Water Bodys
Imported water body geometries generally need to be adjusted manually in terms of elevation. Currently, I select the polygons and adjust their elevation using the Move tool. However, there is no way to check whether all polygons have been processed. It would be useful to have a list similar to the one used for GCPs,…
Average Adjusted Elevations for Water Bodies
Water bodies—except for flowing water—generally form a horizontal plane. The “Get Heights” function in the Edit menu can transfer elevation values from a terrain model to water polygons. It would be helpful to provide an additional option that calculates the mean elevation of a water body and applies it to the entire water…
Defining the Number of Nodes to Be Used per Process
Certain processing steps generate a very high network load, particularly Image Preparation. We use a total of 24 nodes, which leads to network congestion during image processing. If I were to shut down some of the nodes, I would lose processing capacity that could otherwise be used simultaneously by other projects within…
e57 support?
When will Reality Studio support e57 files?
Request for Additional Features Regarding the Site Scan Flight Application
In the current flight application, flight plans are created by defining the flight area based on the latest orthoimages generated via Quick Map. However, in rare cases where Quick Map fails or the positional accuracy of its orthoimages is poor, we currently resort to defining the flight area using the drone's current…
Coordinatesystem for downloadable SLPK mesh
Hi. A client has defined XY and Z coordinate systems in a Sitescan project and used GCP's and everything "after the book". Downloading the LAS result the coordinatesystems defined are kept, but downloading the SLPK mesh and coordinatesystem is changed to the WGS84/EGM96 combo (XY/Z respectively). I guess this is as…
Add the ability to reprocess DSM products in ArcGIS Reality Pro in selected regions/extents
Sometimes, data products are processed incorrectly. But instead of having to reprocess the entire satellite scene, it would be better to support reconstruction at certain extent/regions based on the map's current extent or a polygon mask. The reprocessing can be done using one of the available Matching Methods.
Please consider adding the ability to create traditional ortho products in ArcGIS Reality Pro
Would it be possible to add the ability to create traditional ortho products into ArcGIS Reality Pro? Reality Mapping is the future of photogrammetry and the focus going onwards. However, I have requirements to create traditional ortho sometimes. Adding the ability to create traditional ortho with ArcGIS Reality Pro would…
Add more Matching Method parameters when generating DSM Products in Reality Mapping wizard to be equivalent to Ortho Mapping's
Currently, generating DSM wizard using Ortho Mapping in ArcGIS Pro Advanced support several Matching Methods params such as Semiglobal Matching and Extended Terrain Matching. However, the same parameter is not available in the "newer" Reality Mapping wizard in ArcGIS Pro. Please consider adding this functionality in…
