Quickcapture button to open Survey123 project
1445
03-13-2020 08:22 AM
MikeFiguray
Hello, I am developing a work order tracking system, and some job types are easily recorded by Quickcapture (Debris pickup), and other job types require multiple fields to be filled out (Concrete work). Instead of having the users go back and forth between the 2 apps, is there a way I could use a Url Scheme to open the Survey123 form from quickcapture?
Thank you,
Mike
JohnathanHasthorpe
We will be releasing an integration between QuickCapture and Survey123 in version 1.7 to be released in September 2020. The designer will allow the configuration of buttons that can launch Survey123 and prepopulate questions.
Mandy_Li
Hi Mike, we have this in our backlog already and are planning to implement it for a future release.
Mandy
JohnathanHasthorpe
