Quick Capture Records not Sending anymore
4012
09-23-2021 09:58 AM
by Anonymous User
Not applicable
I have scoured the posts on here and found a few similar sounding issues, but nothing has fixed the problem.  I had hope for this thread , but the suggested solution didn't help.
Situation: We've been using QC for several months and just within the last few weeks several of the users have had records fail to send.  There is no error message, it just hangs like it's trying to send and nothing happens.  Similar to the above post it's just frozen.  There is nothing that pops up giving the option to email the data (i.e. the dialog box outlined in this post does not appear).  We've completely closed and opened the app, made sure to be connected to a solid network and nothing.  These are line records following the users hikes/drives, etc.
This is causing a major issue, so I'm hoping there is something else to try.
Mandy_Li
@Anonymous User First we could try to check if the refresh token is expired - when the refresh token is expired and the user is still in the project, the user can still press the send button, but nothing happens. To rule this out, you can close the project and go back to 'My workspace' page, click the user thumbnail, and see if there's a warning message to ask you to re-enter your password.
If this doesn't help, we will need to check the app's logging to see what went wrong. To enable logging, go to the app menu again, press the hold the About option for 6 seconds until the Reset option shows up. Now click the Settings option, scroll down, switch on Logging. You will notice a floating icon shows up now, that's where the logging info is stored. Now you can repeat the workflow you described in the issue and try to send the records again from your device. If it fails again, click on the floating icon and check the 'Upload' tab. Take a screenshot and send it to us (or if anything went wrong, messages will show as red on this page now).
Let me know if you find anything.
PaulDoherty2
I cannot confirm but this sounds similar to an issue we (+ @JaredDoke)  hit when copying layer and project templates from one organization to another.
Can you try checking off/on "optimize drawing"?
https://doc.arcgis.com/en/arcgis-online/manage-data/manage-hosted-feature-layers.htm#ESRI_SECTION1_7...
It is probably best to put in an Esri Support ticket to be sure, but I hope this helps!
@Mandy_Li any other ideas?
Mandy_Li
by Anonymous User
Not applicable
@Mandy_Li  , great news, it was the refresh token!  So thank you for that!  I will save this as I can see the logging option being useful in the future.
MILLARJosiah
I'm having the exact same issue, and followed these steps and there was a 201 error stating that the issue was with transferring data because it was "forbidden". Not really sure what to do from here. The person uploading the data has a creator/editor account and has successfully published around 30 photos before this issue. I haven't changed anything with the layer its publishing to, and everything works well on my device.
by Anonymous User
Not applicable
Thank you @PaulDoherty2  and @Mandy_Li .  I am getting my hands on one of the phones tomorrow, so this gives me something to work with which. I will report back.
