Microsoft Automate
7612
16
01-11-2021 07:00 PM
AdamCrateau
Does QuickCapture support webhooks using Microsoft Automate (previously Flow)?  We'd like to create a webhook for emailing a group when a capture is submitted.
Tags (3)
2 Solutions
JohnHasthorpe
Hi Adam
There are no QuickCapture modules for Power Automate, meaning that you can't configure QuickCapture webhooks in Power Automate automatically. However, if you create a webhook in Power Automate, you can copy the webhook URL and use it to manually configure the webhook for a project in the QuickCapture web designer (in project settings=>Webhooks).
Once the project is configured and downloaded, the app will call the webhook URL each time a record is uploaded, passing through the submission payload.
I hope this helps.
Thanks
John
JohnathanHasthorpe
Hi Adam
I hope this helps.
Thanks
John
JohnHasthorpe
Hi Adam
I hope this helps.
Thanks
John
JohnathanHasthorpe
Hi Adam
I hope this helps.
Thanks
John
alvarospm
Hi @JohnathanHasthorpe could you please tell me how can I create the webhook in Power Automate for QuickCapture. I did it before for Survey123 following these instructions https://support.esri.com/es/technical-article/000025025 is there something similar for QuickCapture?
Thanks
JohnathanHasthorpe
@alvarospm - Are you using ArcGIS Enterprise?
alvarospm
Yes @JohnathanHasthorpe I am using ArcGIS Enterprise, a Portal
JohnathanHasthorpe
As QuickCapture does not have a connector for Power Automate, the Survey123 steps in https://support.esri.com/es/technical-article/000025025 will not work. You can only use Power Automate with ArcGIS Online for QuickCapture (Not ArcGIS Enterprise).
Cheers
John
alvarospm
Thank you @JohnathanHasthorpe, I hope it will be possible soon.
Do you know if I can use Integromat for QuickCapture ArcGIS Enterprise?
AbiDhakal
@alvarospm -
Do you now have a QuickCapture connector for Power Automate? Are you now able to create a webhook in Power Automate for ArcGIS Enterprise QuickCapture?
Thank you,
Abi
AbiDhakal
@JohnathanHasthorpe -
Can you now use Power Automate with ArcGIS Enterprise for QuickCapture?
Also, would you please be able to provide QuickCapture connector steps link for Power Automate?
Thank you,
Abi
