How do I install an old version of ArcGIS PRO SDK?
5855
7
05-24-2021 08:33 AM
JamalWest2
How do I install an old version of ArcGIS Pro SDK. I previously set the SDK settings to not auto update, but this seems to have been changed recently. My version updated to 2.8 which is causing issues. I simply want to install 2.7. How do I do this?? This should not be hard to do.
Tags (1)
CharlesMacleod
uninstall your current copy. Extensions->Manage Extensions->Installed. Click on the Uninstall button for the ArcGIS Pro SDK for .NET extension. Close and reopen VS and SDK will uninstall.
Then go here: https://github.com/Esri/arcgis-pro-sdk/releases
download version 2.7 and install (proapp-sdk-templates.vsix)
KenBuja
MVP Esteemed Contributor
You can get the older SDKs from here by clicking on a version and downloading the vsix files at the bottom of the wiki page (under "Assets").
CharlesMacleod
JamalWest2
I ran this, but found it doesn't add the utilities also. Anyway I can get those? @KenBuja  @CharlesMacleod
UmaHarano
The Utilities vsix has been uploaded now to the assets section of the 2.7 release page.
Thanks!
Uma
Wolf
by Esri Regular Contributor
Also I would recommend to uncheck the Visual Studio option to 'Automatically update extensions' as shown here:  ProGuide Installation and Upgrade · Esri/arcgis-pro-sdk Wiki (github.com)
By default Visual Studio automatically checks this option so when a new release becomes available your ArcGIS Pro SDK is automatically upgraded.
VidmasKondratas
It would be really nice if "auto update" would be turned off by default and that you can pick the version you want to download from the Extensions manager in Visual Studio. Especially since the incorrect version and auto update will break your build. When I install NuGet packages, they don't auto update and I can pick specific versions.
GKmieliauskas
You can add your suggestion to ArcGIS Pro SDK Ideas.
