Why will one particular layer from my database not load into Pro?
3876
6
07-18-2016 09:56 AM
LyleShakespear
I have a project with multiple layers from my database loaded in to it.  However, I have one layer that won't load into the map.  It's just a simple line layer.  It gives me the error message::   "Failed to add data, unsupported data type."
Any ideas?
DanPatterson_Retired
what is the file type? is it in a geodatabase or a separate file? can you open it in arcmap? if so, export it out in another format in another location and see if that can be loaded
LyleShakespear
It is one of our most common and most used layers in our enterprise geodatabase.  I have layers from this same geodatabase that work just fine but this one won't work.  It opens fine in ArcMap.  I could do a work-around but I'm really trying to get to the bottom of why it won't show.
by Anonymous User
Not applicable
Lyle
 I am sure you have figured this problem out by now but I just ran into this same issue myself. I could see all of the layers in my database but when I tried to add it into my map I would get an error.  I did some poking around and figure out that it was a permission issue. Once I connected to my database using the correct account. I was able to add my layer into the map.
FayuLai
I have same error in Pro.  I was trying to add a layer from my file geodatabase using Pro SDK.  Keep getting "Failed to add data, unsupported data type".  I can manually add it to Pro without any issues.  Any ideas?
Here are my codes:
await QueuedTask.Run(()=>
Uri uri = new Uri(sPrjDB + "\\Map\\Map.gdb\\Pipe");
LayerFactory.Instance.CreateLayer(uri, MapView.Active.Map);
ArcGIS Pro SDK‌ might be a better place to post your query... this thread is quite old
FayuLai
Thank you Dan.  I just searched and found this question.  Yes, I will post my question again in the Pro SDK.
