Why do labels disappear after I convert to annotation in ArcPro?
16106
10
04-30-2020 06:21 PM
BrandonCrawford1
Hi GIS folks,
I'm confused on how conversion on labels to annotations works in ArcPro. It seems a bit more complicated than how it works in ArcMap.
Specifically - whenever I've tried to simply "convert labels to annotation" in ArcPro, they simply disappear. I noticed when I select features then run the conversion to annotation, it sometimes produces an annotation layer (but only for the ones the features that I selected). Regardless, it seems unnecessary that I have to select the features that I want to convert to annotations everytime. If I don't select, it produces an empty annotation layer.
Does anyone know why the labels just disappear unless I select them (again, there were some that I selected and they still disappeared after the conversion)? This seems way more complex than it needs to be. Am I missing something?
On that note - I became fed-up with attempting annotations that I just tried to insert text in the map as a substitute (I just needed to move a single label). This also proved to be confusing. Any words of wisdom or pro-tips people can share about adding text to the map would also be appreciated.
Thank you,
Brandon
JaredPilbeam2
MVP Alum
I'm using Pro v. 3.3.2. And what @MattRummel said worked for me too.
Under Unplaced labels, check Never remove and then zoom out to a level where all your labels are showing. If you don't zoom out it only converts the labels in view. Next, in the Convert Labels To Annotation pane set the conversion scale to whatever works best. I set mine to 1:18,700 because that's the 1 to 1 in my map layout.
