Why are my PDF Layout Maps showing up with weird symbols?
3882
09-01-2021 01:21 PM
KaitlynAbrahamson
Hi Everyone,
I am totally stumped.  When I export a layout in ArcGIS Pro as a PDF, it shows up normal as the original copy on my desktop.  However, when I copy it to a shared folder anywhere, it opens with bizarre symbols like it's corrupt.  I'll attach a screenshot, but I can't figure out what is happening.
3 Solutions
jcarlson
It sounds like a font issue. Your machine would have access to the same fonts that Pro does, so it wouldn't be a problem, but another machine / web interface that lacks those fonts would not display it correctly.
In your export settings, is "Embed Fonts" checked?
- Josh Carlson
Kendall County GIS
David_Brooks
MVP Regular Contributor
The ESRI fonts are needed for marker symbols to work in PDFs.
In the PDF export, select either of these options to test:
Converting to polygon is the fail safe, but you should be fine just embedding the fonts.
David
..Maps with no limits..
KaitlynAbrahamson
Thank you!  It worked!
jcarlson
- Josh Carlson
Kendall County GIS
KaitlynAbrahamson
David_Brooks
David
