Weird lines on my Contents menu
1701
02-08-2022 02:53 PM
Sazudemy
Hi:
I'm using ArcGIS Pro for an online class on edX. When my cursor pass over the "Contents" list, some blurry lines appear and disappear. It looks like the cursor is "dissolving" the words and symbols and regenerating them again. It doesn't affect the map and the things I'm doing but it's difficult to see the items on the list and work with them. I'm including a snapshot of my screen. Maybe someone can help me. I'll appreciate it.
2 Solutions
KenBuja
MVP Esteemed Contributor
Sazudemy
Hi: I called Dell's support and the assistant updated everything in my laptop and found that, in fact, it was the Alienware Command Center. He uninstalled it and checked ArcGIS Pro and the lines disappeared. Then, he installed a new update of the Alienware and, it worked! So, I can use both. Thank you for the tip!!!
KenBuja
Sazudemy
Thanks for replying. Maybe is that.
Sazudemy
Do you know what can happen to my system if I uninstall the Alienware Command Center? It seems to control the fan and temperature of the laptop.
KenBuja
No, I don't know.
Sazudemy
