Symbology from field in the attribute table when added from a geodatabase
6772
7
02-09-2022 07:08 AM
CandiSmith23
Hi wondering if anyone can help. I have a geodatabase and I would like when I add features from it to my map for the symbology be a unique value from a field in the attribute table. How can I set this up so it happens automatically when the data is added?
JayantaPoddar
True. Could you add an integer field, and define the code and description for the subtype. Then use Calculate Field to define appropriate codes based on the TEXT field.
Think Location
Robert_LeClair
Esri Esteemed Contributor
Is your layer already being symbolized by unique values or are you using single symbol symbology?
CandiSmith23
When I add my points from the gdb it comes in as a single point but I would like it to come in with symbols with unique values using my symbology code in the attribute table. I have two pictures one the way it comes in and the way I would like it to come in.
JayantaPoddar
- One way would be to save the layer (with categorized symbology) as a layer file. And add the layer file instead of the Feature Class from the Geodatabase.
- Another option that could work out is the creation of subtypes
Think Location
CandiSmith23
Yes subtype is what is done in other geodatabases I received  but  I can’t seem to add one to mine 😞  it’s not and option in the Field name and when I type it in a get an error.
CandiSmith23
I think I know why it’s not working my field is ‘text’ and I just read it should be long or short integer
JayantaPoddar
Think Location
CandiSmith23
This forum is an awesome source! Thanks to all!
