Viewing Survey Area of an Observation
2526
11
08-16-2022 04:13 PM
PaintedSun
Hello!
I have a large dataset that I want to be able to create a polygons from it to visualize what survey area a person is observing. The dataset consists of:
- Location Data (UTM's, NAD 1983)
- Left Bearing
- Right Bearing
- Visible Distance (in meters)
Can anyone point me in the right direction on how I can do this? I'm very new to mapping so if you can use basic terminology it would be appreciated!
PaintedSun
Oh gosh, I know so little! Yes, I just labelled the field in the excel sheet, not realizing what an OID was until I did some Googling.
I added a column to my excel sheet:
Which gives me this table in Arc GIS Pro:
I entered the code into the Python pane as such:
def circle_section(x, y, start, end, radius, wkid):
    """Creates a circle section.
        x, y: float, coordinates of the center
        start, end: int, start and end of the section in degrees, Nort=0°, East=90°
        radius: float, radius of the section
        wkid: int, well-known id of the coordinate system
        returns an arcpy.Polygon in the chosen coordinate system
    start = int(start)
    end = int(end)
    center = arcpy.Point(x, y)
    center_geo = arcpy.PointGeometry(center, wkid)
    arc_geos = [center_geo.pointFromAngleAndDistance(angle, radius, "PLANAR") for angle in range(start, end, 1)]
    points = [center] +  [ag.firstPoint for ag in arc_geos] + [center]
    return arcpy.Polygon(arcpy.Array(points), spatial_reference=wkid)
def create_view_sheds(in_table, out_features, x_field, y_field, bearing_left_field, bearing_right_field, distance_field, wkid):
    """Creates a polygon feature class with circle sections.
    in_table: str, path to the input table or name of the table in the active map
    out_features: str, path to the output feature class
    *_field: str, names of the fields in the input table
    # create output feature class
    from pathlib import Path
    folder = str(Path(out_features).parent)
    name = str(Path(out_features).name)
    arcpy.management.CreateFeatureclass(folder, name, "POLYGON", spatial_reference=wkid)
    arcpy.management.AddField(out_features, "FID", "LONG")
    with arcpy.da.InsertCursor(out_features, ["SHAPE@", "FID"]) as i_cursor:
        with arcpy.da.SearchCursor(in_table, ["ID", x_field, y_field, bearing_left_field, bearing_right_field, distance_field]) as s_cursor:
            # for each table row
            for oid, x, y, bearing_left, bearing_right, distance in s_cursor:
                # create a circle section
                poly = circle_section(x, y, bearing_left, bearing_right, distance, wkid)
                # write the polygon and the table row's objectid into the feature class
                i_cursor.insertRow([poly, oid])
create_view_sheds("Observations", "memory/Viewsheds", "X", "Y", "BearingLeft", "BearingRight", "Distance", 25832)
The program seems to read it (there are no more error messages) and creates a Viewshed, but... it's blank.
I tried changing the order layer and style to see if it was hidden somehow, but it didn't do anything. Did I edit the code correctly?
PaintedSun
The Fields chart data type says it is 'Long'. Is that appropriate?
