Use ArcPy to combine geoprocessing tools in a loop
3391
10
06-18-2024 04:09 AM
DanHardwick
I have been carrying out some manual analysis on a polygon dataset, selecting all points from a feature layer within 5km and populating the selected records using field calculator. What I am now wanting to do is use some Python to automate this, as I have several features layers to do this for.
This is what I have been running:
arcpy.management.SelectLayerByLocation(
in_layer="Waterbodies",
overlap_type="WITHIN_A_DISTANCE",
select_features="Offtaker_Utility",
search_distance="5 Kilometers",
selection_type="NEW_SELECTION",
invert_spatial_relationship="NOT_INVERT")
arcpy.management.CalculateField(
in_table="Waterbodies",
field="Utility_5km",
expression='"Yes"',
expression_type="PYTHON3",
code_block="",
field_type="TEXT",
enforce_domains="NO_ENFORCE_DOMAINS")
I could just continue to do this manually or even just edit the script to change 'select_features' in selectbylocation, and the 'field' in calculatefield, but I want to automate this if possible. I am fairly new to ArcPy and haven't used it much in the last 2-3 years, so slowly learning my way again and trying to automate some tasks using it to get some real world and work workflows setup.
I decided to do this in an ArcGIS Pro notebook, and so far I have:
  1. set the workspace to look at my geodatabase
  2. Used a function to list all feature classes
  3. Filtered those feature classes to show only the ones relevant for this analysis
  4. Carried out the first geoprocessing task of looping through each feature and selecting the relevant polygons
This is the code:
arcpy.env.workspace = r"my file path\Datscha_output.gdb"
feature_classes = arcpy.ListFeatureClasses()
filtered_fcs = [fc for fc in feature_classes if "Offtaker" in fc]
for fc in filtered_fcs:
    print (fc)
    print (filtered_fcs)
    in_layer="Waterbodies_Definitive_Version",
    select_features=fc,
This all works, but I also need to incorporate another geoprocessing task of calculating a field. This is where I am a bit stuck. I think I need to include the calculate field function into the above loop, as I need to tell the script to select all points from Offtaker_a, then calculate the relevant field in polygon dataset, then loop onto the next point feature of Ottaker_b etc. etc.
The calculate field function has a parameter for what field to update, so I presume I must need to create a variable to look at each field in the table, or similar?
Tags (3)
BobBooth1
Dan, glad I could help!
