ArcGIS Pro popup element not sticking
1433
07-03-2024 10:42 PM
Sian_Doherty_GHD
I have configured popups in ArcGIS Pro but they sometimes don't stick.
There are multiple layers where this is a problem and for the most part the majority of the fields are the same with some additions depending on the asset type.
The gist of my popup element is
var popupContent = "<table style='border-collapse: collapse;'>"; // Initialize popup content as an HTML table
var fields = []; // Array to hold the fields and their values
var cellPadding = "8px"; // Adjust padding as needed
// Access feature attributes and push them into the fields array
Push(fields, { name: "Facility ID", value: $feature.facility_ID });
Push(fields, { name: "Name", value: $feature.name });
Push(fields, { name: "Description", value: $feature.description });
Push(fields, { name: "Asset Status", value: DomainName($feature,"asset_status") });
Push(fields, { name: "Beam Type", value: DomainName($feature,"type") });
Push(fields, { name: "Beam Position", value: DomainName($feature,"position") });
Push(fields, { name: "Material", value: DomainName($feature,"material") });
Push(fields, { name: "Install Date", value: Text($feature.install_date,"dddd DD MMMM Y") });
Push(fields, { name: "Length", value: Round($feature.length,2) + " "+ DomainName($feature,"distance_UOM")});
Push(fields, { name: "Width", value: Round($feature.width,2) + " "+ DomainName($feature,"distance_UOM")});
Push(fields, { name: "Maintained By", value: DomainName($feature,"maintained_by") });
Push(fields, { name: "Owner", value: DomainName($feature,"ownership") });
Push(fields, { name: "Condition Assessment Rating", value: DomainName($feature,"ca_rating") });
Push(fields, { name: "Condition Assessment Date", value: Text($feature.ca_date,"dddd DD MMMM Y") }); // Include formatted CA date directly
Push(fields, { name: "Condition Assessment Comments", value: $feature.ca_comments });
Push(fields, { name: "Collection Method", value: $feature.collection_method });
Push(fields, { name: "Source", value: $feature.source });
Push(fields, { name: "Source Date", value: Text($feature.source_date,"dddd DD MMMM Y") });
Push(fields, { name: "Berth", value: $feature.berth});
Push(fields, { name: "Precinct", value: $feature.wharf});
Push(fields, { name: "Port", value: DomainName($feature,"terminal")});
Push(fields, { name: "Comments", value: $feature.comments});
// Count the number of non-empty fields
var validFieldCount = 0;
for (var i = 0; i < Count(fields); i++) {
    var field = fields[i];
    if (field.value != null && field.value != "" && field.value != 0 && field.value != 0 + " ") {
        validFieldCount++;
// Add fields to popup content
        popupContent += "<tr style='background-color:" +  "'><td style='padding:" + cellPadding + "'><b>" + field.name + ":</b></td><td style='padding:" + cellPadding + "; '>" + field.value + "</td></tr>";
popupContent += "</table>"; // Close the HTML table tag
// Return statement adjusted for popupElement
return {
    type: "text",
    text: popupContent
Sometimes it reverts to
var popupContent = " " + field.name + ": " + field.value + " "; // Close the HTML table tag // Return statement adjusted for popupElement return { type: "text", text: popupContent };
Other times it can revert to
return {
type: "text",
text: popupContent
which is the default arcade element text option when clicking on the 'Arcade' button in the configure popups dialog box in ArcGIS Pro.
I cannot for the life of me figure out what is going on. i have checked the field types and names and it will preview OK, but it just doesn't stick. Can anyone help or should i escalate to tech support?
The reason i'm specific with my listing of fields is because i have another question pending about the fields being returned in alphabetical order when i use the following as my popup:
// Field map to hold the field names and their corresponding values
var fieldMap = {
    "Facility ID": $feature.facility_ID,
    "Name": $feature.name,
    "Description": $feature.description,
    "Wharf": $feature.wharf,
    "Berth": $feature.berth,
    "Condition Assessment Rating": $feature.ca_rating,
    "Condition Assessment Date": Text($feature.ca_date, "dddd DD MMMM Y"),
    "Condition Assessment Comments": $feature.ca_comments,
    "Collection Method": $feature.collection_method,
    "Source": $feature.source,
    "Source Date": Text($feature.source_date, "dddd DD MMMM Y")
var i = 0;
for (var fieldName in fieldMap) {
    var fieldValue = fieldMap[fieldName];
    if (fieldValue != null && fieldValue != "") {
        var rowColor;
        if (i % 2 == 0) {
            rowColor = "#FBFBFB";
        } else {
            rowColor = "#EDEDED";
        popupContent += "<tr style='background-color:" + rowColor + "'><td style='padding:" + cellPadding + "'><b>" + fieldName + ":</b></td><td style='padding:" + cellPadding + "'>" + fieldValue + "</td></tr>";
        i++;
return {
type: "text",
text: popupContent
Warm regards,
Sian Doherty
Spatial Analyst (GHD Digital)
palatisa1
Do this and force I think the cache running to stop. You can usually salvage it this route. Project recovery is also mostly good if it crashes. I tend to pause the map OP if I know I’m gonna add a lot of data.
palatisa1
@palatisa1 wrote:
Do this and force I think the cache running to stop. You can usually salvage it this route. Project recovery is also mostly good if it crashes. I tend to pause the map OP if I know I’m gonna add a lot of data https://9apps.ooo/ .
I got this,..
Sian_Doherty_GHD
Thanks @palatisa1
Unfortunately project recovery will do nothing as even if I save the project after previewing the successful pop-up, it just doesn't stick. Cache is set to clear upon exit. I've just got snippets saved as .js files and I usually just copy and paste it back prior to publishing. However, sometimes that works and sometimes it doesn't, so i'm looking for a permanent solution.
