Unable to Adjust Layer Order in ArcGIS Pro 3.4.2
5790
21
02-07-2025 08:55 AM
YingboDong
Hello everyone,
I am currently facing an issue where I am unable to adjust the layer order in ArcGIS Pro. Here's a brief overview of the situation:
  • I am working in the Map tab and have already clicked on the Drawing Order button to enable layer order adjustments.
  • Despite this, I am unable to drag layers up or down in the Contents pane to adjust their order.
  • I also tried creating a new project, but the problem persists, and I still cannot reorder the layers.
  • My ArcGIS Pro version is 3.4.2.
If anyone has encountered a similar issue or has a solution for this, I would greatly appreciate your help. Thank you in advance!
3 Solutions
DanielFox1
Thank you for confirming @YingboDong
Can you try the following steps to work around this issue? Let me know if this works for you.
The current workaround is to uninstall the update KB5050094.
Steps to do this:
1. Navigate to Start > Settings > Update & Security > Windows Update > View update history
2. At the top of the page select 'Uninstall updates' and select the KB5050094 update to uninstall
3. After the update has successfully been uninstalled, restart computer.
4.Launch ArcMap or ArcGIS Pro and you should now be able to move layers as expected.
EMKcartografie
What worked for me was unplugging any additional monitors on my laptop, restart the laptop, reorder the layers on my laptop screen, plug back in the additional monitors.
EMKcartografie
Eugene_Adkins
Unfortunately, you do not seem to be the only one.
YingboDong
did you also meet this?
Eugene_Adkins
Not me. I'm not using the same version of Pro as you. If you click "Unfortunately" in my original reply, it will bring you to another post where a different user is experiencing the same problem after updating to version 3.4.2.
YingboDong
okk Thank you. I try to ask the author
DanielFox1
Hi @YingboDong
Have you had the following windows update applied to your machine
KB5050094
Is your machine Windows 11 also
YingboDong
Hi Daniel,
Yes I think I had update KB5050094.
My machine is Windows 11
Is this the main reason?
DanielFox1
Steps to do this:
YingboDong
thanks it works
AMikolajczak
Hello,
Several people in my office have encountered the same issue this morning. They have done the Windows Update uninstall workaround with no success. Any help would be appreciated.
