I am trying to populate a new layer based off of some old data I found. However, this one text field that is housing Date info is a little odd. There are spaces between everything and there is a "12:" after almost every entry. How do I get this into my new date field?
So the first thing to do is replace the 12: in your text field to be a valid (generic) time. To do this, I calculated the existing text field using the Replace function:
Replace($feature.date_text, '12:', '12:00:00') - see first image below.
Then in the date/time field, I did another field calculation using the following function:
$feature.date_text - see second image below.
The date/time field now has a valid date/time value that shows 12 noon.
Hm, didn't quite work for me. Not sure where all those 000s are coming from
Hmmmm...that's strange. Can you share the data with me so I may do some testing? My email is rleclair at esri dot com
