Suitability Modeler Troubles
3274
6
03-31-2022 06:34 PM
IanBootsmiller
Hey everyone! I am trying to run the suitability modeler with a Euclidean distance road dataset, a wetland data set, and a landcover dataset. I have set them all to the same cell size and extent. After I am all done with formatting the data within the suitability modeler, I run the tool and it gives me a notification that says that I cannot run the modeler because it is not at full resolution. Does anyone have insight to why this might be?
Thanks!
Tags (1)
DanPatterson
MVP Esteemed Contributor
Transformation pane in Suitability Modeler—ArcGIS Pro | Documentation
Under Run the Transformation
To run the model at full resolution, click Run on the Suitability tab. The transformations in the raster function chain are calculated at full resolution, producing a more precise suitability map.
... sort of retired...
EmilyE
I'm having a similar issue. However, when I click Run in the Suitability tab, I'm still given the error message "Locate regions not ready to run: missing full resolution suitability map".
IanBootsmiller
Yes, this is precisely what it is telling me as well.
EmilyE
I ended up running the Locate Regions geoprocessing tool instead, and that worked for me!
IanBootsmiller
Thanks Emily! However, when I try to run the suitability map at full resolution in the suitability tab, it is not letting me run it. I click the run button, but it does nothing! So frustrating!
DanPatterson
Escalate to Tech Support would be the best option.
