Status arrow on map beside a waterbody
578
02-12-2021 04:00 AM
RonanMcShane
I wish to put an up or down arrow beside a lake.
The up arrow indicates water quality status has improved.   The down arrow meaning status has declined.
In the table linked to this map I would have for example 2018 status "good" and in the next column 2020 status "bad".
Can I link the status icon arrow to these columns as a function e.g. if status has declined arrow points down?
DavidPike
MVP Frequent Contributor
Hi Ronan, you should be able to vary the symbols rotation by a field. Vary symbology by rotation—ArcGIS Pro | Documentation
I guess you can either create a new field 'rotation' for example, and do a field calculation where if == 'good' return 0 else return 180 (if the arrow is up normally!)  I think you can also skip the step of creating the rotation field by utilising an expression.
Robert_LeClair
Esri Notable Contributor
There was a similar question using ArcGIS Online Map Viewer and Arcade.  Arcade is also of use in ArcGIS Pro so worth a look.
