Spyder IDE no longer works after upgrade to ArcGIS Pro 2.5
9289
35
02-08-2020 11:16 AM
JohnHuillery1
Error:
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-nbextension-script.py", line 6, in <module>
from notebook.nbextensions import main
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\notebook\__init__.py", line 25, in <module>
from .nbextensions import install_nbextension
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\notebook\nbextensions.py", line 28, in <module>
from ipython_genutils.py3compat import string_types, cast_unicode_py2
ModuleNotFoundError: No module named 'ipython_genutils.py3compat'
DEBUG menuinst_win32:__init__(199): Menu: name: 'Anaconda${PY_VER} ${PLATFORM}', prefix: 'C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3', env_name: 'arcgispro-py3', mode: 'user', used_mode: 'user'
DEBUG menuinst_win32:create(323): Shortcut cmd is C:\Users\JHUILL~1\AppData\Local\Temp\_MEI144042\pythonw.exe, args are ['C:\\Users\\JHUILL~1\\AppData\\Local\\Temp\\_MEI144042\\cwp.py', '"C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3"', '"C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3\\pythonw.exe"', '"C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3\\Scripts\\spyder-script.py"']
DEBUG menuinst_win32:create(323): Shortcut cmd is C:\Users\JHUILL~1\AppData\Local\Temp\_MEI144042\python.exe, args are ['C:\\Users\\JHUILL~1\\AppData\\Local\\Temp\\_MEI144042\\cwp.py', '"C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3"', '"C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3\\python.exe"', '"C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3\\Scripts\\spyder-script.py"', '--reset']
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\runpy.py", line 183, in _run_module_as_main
mod_name, mod_spec, code = _get_module_details(mod_name, _Error)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\runpy.py", line 109, in _get_module_details
__import__(pkg_name)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\__init__.py", line 3, in <module>
from . import (features, geoanalytics, geocoding, geometry,
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\features\__init__.py", line 28, in <module>
from . import enrich_data
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\features\enrich_data.py", line 10, in <module>
import arcgis.network as network
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\network\__init__.py", line 7, in <module>
from ._layer import NetworkLayer, NetworkDataset, ClosestFacilityLayer, ServiceAreaLayer, RouteLayer, NAJob
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\network\_layer.py", line 8, in <module>
from arcgis.mapping import MapImageLayer
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\mapping\__init__.py", line 8, in <module>
from ._types import WebMap, WebScene, MapImageLayer, MapImageLayerManager, VectorTileLayer, OfflineMapAreaManager, PackagingJob
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\mapping\_types.py", line 19, in <module>
from arcgis.widgets import MapView
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\widgets\__init__.py", line 2, in <module>
from arcgis.widgets._mapview import MapView
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\widgets\_mapview.py", line 15, in <module>
from ipywidgets import widgets
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\ipywidgets\__init__.py", line 25, in <module>
from .widgets import *
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\ipywidgets\widgets\__init__.py", line 4, in <module>
from .widget import Widget, CallbackDispatcher, register, widget_serialization
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\ipywidgets\widgets\widget.py", line 18, in <module>
from ipykernel.comm import Comm
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\ipykernel\comm\__init__.py", line 1, in <module>
from .manager import *
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\ipykernel\comm\manager.py", line 15, in <module>
from .comm import Comm
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\ipykernel\comm\comm.py", line 9, in <module>
from ipykernel.kernelbase import Kernel
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\ipykernel\kernelbase.py", line 19, in <module>
from jupyter_client.session import utcnow as now
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\jupyter_client\session.py", line 56, in <module>
from zmq.eventloop.ioloop import IOLoop
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\zmq\eventloop\__init__.py", line 3, in <module>
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\zmq\eventloop\ioloop.py", line 78, in <module>
while _IOLoop.configurable_default() is not _IOLoop:
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\tornado\ioloop.py", line 328, in configurable_default
from tornado.platform.asyncio import AsyncIOLoop
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\tornado\platform\asyncio.py", line 34, in <module>
asyncio.set_event_loop_policy(asyncio.WindowsSelectorEventLoopPolicy())
AttributeError: module 'asyncio' has no attribute 'WindowsSelectorEventLoopPolicy'
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-nbextension-script.py", line 10, in <module>
sys.exit(main())
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\jupyter_core\application.py", line 267, in launch_instance
return super(JupyterApp, cls).launch_instance(argv=argv, **kwargs)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\traitlets\config\application.py", line 664, in launch_instance
app.start()
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\notebook\nbextensions.py", line 988, in start
super(NBExtensionApp, self).start()
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\jupyter_core\application.py", line 256, in start
self.subapp.start()
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\notebook\nbextensions.py", line 716, in start
self.install_extensions()
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\notebook\nbextensions.py", line 695, in install_extensions
**kwargs
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\notebook\nbextensions.py", line 211, in install_nbextension_python
m, nbexts = _get_nbextension_metadata(module)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\notebook\nbextensions.py", line 1122, in _get_nbextension_metadata
m = import_item(module)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\traitlets\utils\importstring.py", line 42, in import_item
return __import__(parts[0])
sys.exit(main())
app.start()
self.subapp.start()
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\notebook\nbextensions.py", line 896, in start
self.toggle_nbextension_python(self.extra_args[0])
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\notebook\nbextensions.py", line 872, in toggle_nbextension_python
logger=self.log)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\notebook\nbextensions.py", line 483, in enable_nbextension_python
logger=logger)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\notebook\nbextensions.py", line 380, in _set_nbextension_state_python
(arcgispro-py3) C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3>
DanPatterson
MVP Esteemed Contributor
crank up pro and check your environment first
... sort of retired...
DryCreekEng
Thanks Dan. I did have to remove an environment from Pro to get the command prompt to find the right env. However, when I run the Python Command Prompt (as admin) I still get the error below. I think I am done trying to install spyder. I'll just keep using PyScripter.
DanPatterson
never seen that, that is a conda issue when it was trying to download libspatialindex...bz2
And you don't run "python" from there... python has to run a batch file.
/blogs/dan_patterson/2017/07/01/arcgis-pro-2-creating-desktop-shortcuts
it is broken down for you
ZacharyHart
I too give up. I CANNOT get spyder of any version to install with 2.5. I've done more clean-clean uninstalls of the entire environment than I care to remember, I've done via Python command line, i've tried over and over again with the stupid package manager. I just want my Spyder IDE. The most recent failure of trying to install from the command line corrupted my cloned environment and all the jupyter labs & extensions all ruined. I've tried tech support and the analyst is convinced it is because of my (work at home) internet speed!
None of this should be so hard! Hours upon hours wasted again!
DanDeegan
New Contributor III
Spyder was the IDE I was using when I got in to Python so I am fond of it. However, it has been a complete waste of my time for the better part of a year.
VSCode + Jupyter notebook works for me. I do miss the variable explorer. There is something like it in VSCode but it is hard to read because of the color scheme. That is my only complaint.
Unless you have some very specific need cut your losses.
DanPatterson
Wish I could narrow down your problems...
I just installed Spyder 4.1.3 in ArcGIS Pro Beta 1.
no clone, installed in the base environment using conda install spyder --no-pin.
I install in a simple path ( c:\ arc_pro ) and I have never had install problems.
Admin of my machine, installed for myself (not all users).
