Share branch versioning to AGS
5315
12
03-11-2021 05:17 AM
Antonio_Dang
New Contributor II
Hi there!
Im trying to share a feature service with branch versioning to AGS but cant enable the version management:
Does share branch versioning only with portal and enterprise and not AGS standalone?
thx for any advice!
ccharping_patrickco
New Contributor III
Per ESRI documentation at https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/overview-of-versioning-in-a... you need at least a Standard or Advanced license.
ClaudioRuschel
New Contributor III
I understand that these licenses are needed to manage the geodatabase content. But, considering that one wants to edit a Feature Service, I think it is required only an "Editor" user from ArcGIS Portal if it is available through a Web GIS application. If you want to use ArcGIS Pro to edit this service, beyond the Portal´s "Editor" role, is it also needed an Standard or Advancee license?
Antonio_Dang
New Contributor II
Hi there, sry for late reply.
But you workaround works fine 🙂
Strange that we have to found a workaround like this, hope this stil work in the next ags update 🤔
