Selection Tab and Exclusion Set
268
05-15-2025 03:45 PM
DavidGray1
Hello Community;  Hopefully a quick question. I have added an existing layer to a new Project. The existing layer was exported from a different project. I am getting the red exclamation mark next to the layer in the Contents Pane. Looking at Properties for that layer it is showing a message saying you must clear an exclusion set from the Selection Tab. Where is the referenced Selection Tab and how does one look for a defined exclusion set?
The line features in that layer was clipped to a box in the drawing it was subsequently exported from as a layerfile.      I notice that the source shapefile for that layer is now also clipped even though it was external to Pro before clipping.   ????    Dave
RyanUthoff
MVP Regular Contributor
The Selection Tab is in the layer properties. Right click the layer on the contents pane in your map and click properties. Then click the selection tab. This documentation has some information about it.
