PointZ to Point
7194
08-06-2021 10:35 AM
Henry
I'm aware of some tools/workflows for adding 3D elevation data to point geometry (https://community.esri.com/t5/arcgis-pro-questions/point-to-pointz/td-p/356302). Is there a similar way to do the reverse?
With a PointZ Feature class, is it possible to convert to a simpler Point feature class, without the Z data?
Thanks!
Henry
DanPatterson
MVP Esteemed Contributor
Tools that honor the "output has Z values" Environment setting,
Output has Z Values (Environment setting)—ArcGIS Pro | Documentation
can be used.
Both of these tools can be used.  Just set the Environment Tab to disable Z
Feature Class To Feature Class (Conversion)—ArcGIS Pro | Documentation
Copy Features (Data Management)—ArcGIS Pro | Documentation
... sort of retired...
Robert_LeClair
Esri Esteemed Contributor
Henry - one way that I can think of is to create a new (non-Z value) feature class in your geodatabase with the same attribute schema as the input.  Then run the Append geoprocessing tool to append the Z-enabled data to the new empty feature class.  That should work...
JayJohnsonWashoeCounty
Another easy way to do this would be to add an X and Y field to the PointZ feature class and calc their values, then Export table (the table only).  Then right click the exported table and DisplayXY Data.
Jay
Washoe County GIS
DanPatterson
can be used.
JayantaPoddar
As mentioned by Dan, please disable "Output has Z values" in Tool's environments setting > Z Values.
Think Location
