Measuring the Area of Overlap Between Polygon Layers
536
08-19-2022 10:50 AM
LucasBeck
Hi Everyone,
I am using ArcGIS Pro 2.60. I am trying to calculate the area of overlap between features found in two polygon layers. What I ultimately need is a table where the name of the features in one layer are listed along with a measure of the area of overlap each named feature has with the polygons in the second layer.  Do folks know of a tool I can use to find this information efficiently? Thank you so much.
MicZatorsky_AEC
Tabulate Intersection will do the job efficiently, but according to the documentation, you'll need at least ArcGIS Pro 2.8
BarryNorthey
Note: looks like this tool requires an Advanced license.
The license level was problematic when I was working as all installations had a Basic license deployed by default but staff could switch to a scarce Advanced license (and extension licenses) if available and then forgot or declined to switch back or off. We didn't have any Standard licenses. I became the license police out of necessity  BarryNorthey_2-1661115306000.png
