login to ORGANIZATIONAL portal via Arcgis Pro 3.2 via python notebook
2614
7
07-05-2024 11:09 AM
KevinPreston
How do I login to my organizational portal?  I used the same credentials I always use, but the portal does not recognize me.  Am I using the wrong url, or is there some extra parameters needed for organizational login?
Attempting to login to organizational portal (https://osugisci.maps.arcgis.com/home/index.html) within the Arcgis Pro 3.2.  I followed the 'Accessing Data in a Portal Using ArcGIS API for Python' tutorial at Esri's training website, although they only have tutorial for Pro 3.0 and Pro 3.1.  I am using python in the notebook:
The error:
CodyPatterson
MVP Regular Contributor
Hey @KevinPreston
Are you logged into ArcGIS Pro with the account that you'd like to use in the Notebook?
If so, attempt this and see what the outcome would be:
This connects to the home portal that is associated with the logged-in account, it is essentially identical to the method you are trying.
Hope that helps!
Cody
jcarlson
MVP Alum
Just use the basic portal URL, no need to elaborate beyond the .com.
gis = GIS("https://osugisci.maps.arcgis.com", "user", "pass")
Also, when it's just an AGOL org, you can leave it at "https://arcgis.com" and should still work, since your username / password is for AGOL as a whole. It will pick up your org once you're logged in.
- Josh Carlson
Kendall County GIS
KevinPreston
The proposal doesn't work.
jcarlson
MVP Alum
Can you try this and report on what it shows you? This is connecting to your org as an anonymous user:
from arcgis.gis import GIS
gis = GIS('https://osugisci.maps.arcgis.com')
print(gis)
Here's what I see:
In other words, it's not a problem with connecting to the organizational AGOL, it's literally what the error message is showing you, a problem with your credentials.
- Josh Carlson
Kendall County GIS
KevinPreston
here's my output.  To rephrase my process: I'm logged in to the arcgis pro 3.2 application (remotely via school's Citrix application), then I start the notebook from within the arcgis pro 3.2, then using the same credentials used to access the arcgis pro 3.2, I login to 'GIS' via python-notebook, but the authentication process is seen as invalid.
CodyPatterson
Hey @KevinPreston
Hope that helps!
Cody
KevinPreston
It seems to be working.  I restarted a new notebook without attempting to login via the notebook.  As you allude to, it seems that something already detects I'm logged in via Arcgis pro 3.2:
CodyPatterson
Hey @KevinPreston
Sounds great, glad to see things are working!
Cody
