How do I login to my organizational portal? I used the same credentials I always use, but the portal does not recognize me. Am I using the wrong url, or is there some extra parameters needed for organizational login?
Attempting to login to organizational portal (https://osugisci.maps.arcgis.com/home/index.html) within the Arcgis Pro 3.2. I followed the 'Accessing Data in a Portal Using ArcGIS API for Python' tutorial at Esri's training website, although they only have tutorial for Pro 3.0 and Pro 3.1. I am using python in the notebook:
The error:
Just use the basic portal URL, no need to elaborate beyond the .com.
gis = GIS("https://osugisci.maps.arcgis.com", "user", "pass")
Also, when it's just an AGOL org, you can leave it at "https://arcgis.com" and should still work, since your username / password is for AGOL as a whole. It will pick up your org once you're logged in.
The proposal doesn't work.
