Good morning group,
I am starting testing ArcGIS Pro editing with a branched FC using a feature service in ArcGIS Portal
The feature class has fields attached to domains, and these fields are required, So null values are not accepted.
When I try to edit and draw a polygon shape, before I finish drawing the shape, I got the following error messages, and I cannot finish drawing the polygon:
Failed to create <FC>
Value doesn't fall within Domain: DmProjectDivision
Value doesn't fall within Domain: DmProjectType
Value doesn't fall within Domain: DmProjectMaterial
Value doesn't fall within Domain: DmProjectStatus
This FC is currently edited in ArcMap and SDE traditional versioning without any problem.
Please advise.
