Issues Editing Branched FC with ArcGIS Pro
430
8
02-28-2024 05:24 AM
SanchezNuñez
Good morning group,
I am starting testing ArcGIS Pro editing with a branched FC using a feature service in ArcGIS Portal
The feature class has fields attached to domains, and these fields are required, So null values are not accepted.
When I try to edit and draw a polygon shape, before I finish drawing the shape, I got the following error messages, and I cannot finish drawing the polygon:
Failed to create <FC>
Value doesn't fall within Domain: DmProjectDivision
Value doesn't fall within Domain: DmProjectType
Value doesn't fall within Domain: DmProjectMaterial
Value doesn't fall within Domain: DmProjectStatus
This FC is currently edited in ArcMap and SDE traditional versioning without any problem.
Please advise.
George_Thompson
Esri Frequent Contributor
If the feature class (FC) you mention above is edited in ArcMap, then it cannot be branch versioned also?
FC's are either Branch or Traditional versioned.
Are you just editing a feature service via ArcGIS Pro?
--- George T.
SanchezNuñez
Thanks @George_Thompson
We have a production environment where we are currently editing in SDE Traditional versioning with ArcMap.
We have a new development environment where we have an SDE branched database. In this new database  I made a copy of the FC, versioned, and published as feature service in our development ArcGIS Portal.
I am just starting testing the editing process, and I am getting this error message.
Thanks
George_Thompson
Ah ok. Are you publishing to Enterprise 10.6.1?
Can you publish just a FC with no domains to branch versioning and edit in Pro?
--- George T.
SanchezNuñez
Hi @George_Thompson ,
I tried with a FC without domains and it works fine, or a FC accepting null values in the domain field and it works.
But in our case for some fields we do not want the null values, we want to make sure that user selects a value.
Please advise
George_Thompson
I am not sure why that is happening. It may be best to work with technical support to dig into this issue.
--- George T.
SanchezNuñez
Good morning group,
Please advise.
Scott_Harris
@SanchezNuñez try unchecking "Enforce attribute validation" in Options > Editing > General
Doc here:
https://pro.arcgis.com/en/pro-app/3.1/help/editing/change-general-editing-tool-settings.htm
JoseSanchez
Occasional Contributor III
Thank you @Scott_Harris
 Unchecking "Enforce attribute validation"  worked.
Thanks
