How to split string after first word
5068
08-03-2020 04:28 AM
LiorHershkovitz
I have a filed of trees botanical name, now I have to separate it to Genus field and Species field.
Which means I have to extract the first word (Genus) and the second one (Species).
Something like text to column in Excel
Using arcgis pro or online
Thanks!
Lior
Tags (3)
Egge-Jan_Pollé
Hi Lior Hershkovitz,
I guess you are going to use the ArcGIS Arcade expression language to get this done.
You can test this simple script in the ArcGIS Arcade Playground:
var tree = "Prunus virginiana";
var sepValues = Split(tree, ' ');
// return sepValues[0]; // Genus - Result: Prunus
return sepValues[1]; // Species - Result: virginiana
Let's suppose your column with tree names is called TREE. To apply this split on the whole column at once, you can use:
Split($feature.TREE, ' ')[0] // Genus
and
Split($feature.TREE, ' ')[1] // Species
HTH,
Egge-Jan
Egge-Jan_Pollé
and
HTH,
Egge-Jan
LiorHershkovitz
Thanks!
in online, I made calculate field with the expression you wrote.
You are the man!
