How to copy all field names and aliases into Excel?
3407
02-03-2022 06:47 PM
Hayley
Hi there,
I am trying to copy the field names and aliases of my layer into excel in this exact format (field names one column, alises column next to it) rather than the look of an attribute table with the field names on top and attributes under.
Is there an easy way to do this? Thanks!
HL
JohannesLindner
MVP Alum
  1. Open the "Fields view of your layer
  2. Select All, Copy (Ctrl + C)
  3. Open an Excel sheet, paste (Ctrl + V)
Have a great day!
Johannes
JohannesLindner
MVP Alum
Have a great day!
Johannes
KoryKramer
Esri Community Moderator
I came to this post to provide the same solution. Nice answer @JohannesLindner !
@Hayley if that works for you, please accept Johannes' answer as the solution. Cheers.
Hayley
This worked perfectly, thank you!
HL
