How to convert a FeatureClass to FeatureLayer
4515
04-15-2021 03:14 PM
dkoerner
while going though this tutorial: https://pro.arcgis.com/en/pro-app/latest/help/analysis/networks/create-and-use-a-network-dataset-wit...
I fail at step "connect network dataset transit source to streets". The tool errors that the Streets dataset is not a FeatureLayer. It appears to be a FeatureClass. Ignoring that the tutorial instructions appear to be broken (not surprised) I tried to find out how to convert a FeatureClass to a FeatureLayer but failed after a couple of hours (not surprised either).
Can somebody help me?
Best,
David
Tim_McGinnes
Try the Make Feature Layer tool. There are some tools that say they need a feature layer but will happily work with a feature class, however this one may actually need a feature layer. The tool documentation does say feature class though...
What's the actual error you are getting?
DanPatterson
MVP Esteemed Contributor
Did you try the Copy Features (Data Management) tool?   It will produce a new file (featureclass) which when added to a map is a featurelayer.
... sort of retired...
Tim_McGinnes
dkoerner
Hey thanks everybody for your swift response! I managed to resolve the issue 👍
