Help! Can't add folder connections or data to Arcgis PRO
10003
13
10-18-2022 03:26 PM
MariaPaula27
Hello,
I'm trying to add data to a new project of Arcgis Pro but it is not working. When I try the only option that appears is "open", instead of "ok" and the type of archive is always "default", I can't change it.
I don't know what to do, I really need this to work 😞
Thanks in advance
ChristopherCounsell
MVP Frequent Contributor
When adding a folder connection, the final selection should be the folder. In the photo provided you are selecting a raster dataset. You can't make a folder connection to a raster file.
Go up one level in the pop-up and connect to the folder containing the raster files.
This is standard for some spatial/drawing software. Helps with indexing and other aspects as the software is chatty with the folders you connect to. Best to remove folder connections you no longer need as the project grows.
https://pro.arcgis.com/en/pro-app/latest/help/projects/connect-to-a-folder.htm
BarryNorthey
I checked both Pro 3.0.2 and 2.9.3 and in both cases my Add Folder Connection window only shows the "Folders" option in the pull down you have outlined in red. I am not sure how data sources got listed.  Try going up levels BarryNorthey_0-1666150981310.png in the tree until you see the folder that you want to connect to.
Alternately, suggest that you Refresh the Folders connections in the Catalog pane and try again or restart Pro.
As a last resort, Open File Explorer and drag and drop the target folder onto Folders in the Catalog pane.
JoWright
I'm having the same issue as the op with 2.9.2. Going up a level doesn't help but the drag and drop works.
CharlesBintliff
Has anyone solved this issue, i'm having the same problem
BarryNorthey
JoWright reported that Open File Explorer and drag and drop the target folder onto Folders in the Catalog pane worked. Did you try that?
DonnaKattengell
I am having the same issue but not when I am clicking a raster. I am trying to select a folder and am getting “open” instead of “ok.” Any ideas on what I should do? We can’t figure out why this is happening and have reinstalled. Every other computer in my unit works fine with an “ok” button but mine will only say “open.”
ChristopherCounsell
What are you adding? If it's a folder connection it'll let you select the
folder
If you're adding something else, like a database connection or another
file, the folder will show 'open' as it's prompting you to open the folder
and select the file
DonnaKattengell
Here is the process I am taking, maybe it will help you help me. 🙂
Any and all help is appreciated. This is driving us crazy.
ChristopherCounsell
You're doing the right steps, and from the history of this post the community doesn't appear to be able to assist any further.
This needs to go to Esri technical support who can investigate it as a potential defect.
You can try the workaround above of dragging the folder into the catalog pane from file explorer.
Looking at this more broadly it seems users have had this issue when working through VPNs, virtual machines, or cloud environments. So maybe there is something going on with your environment.
You could try upgrading ArcGIS Pro, or sharing more information about your environment so there's a common thread between users reporting this behaviour.
Wild guess based on your C drive, that this is a training VM environment?
