Graduated Symbols overlap! but they should not.
600
03-18-2022 02:45 AM
barrylim
Hi all, I tried to set graduated symbols, but now they overlap my point features, even if they are below them in the layers pane.
Thx in advance!
Robert_LeClair
Esri Notable Contributor
What release of ArcGIS Pro are you using?  I'm using ArcGIS Pro 2.9.2 and have attempted to mimic your Map View with different data.  I'm not seeing the same thing as you as my point layer is obscured by the polygon layer as Pro draws from the bottom up as you know.
barrylim
okay, now I realised it was the computer in my university with Version 2.8.0!
barrylim
Hey Robert, thank you for your reply, i'm using the exact same release as you. Maybe you could check my attached arcgis project file? Because I have no answer for this problem.
Best wishes!
