Geoprocessing history in INSPIRE metadata
679
12-16-2021 05:15 AM
Labels (3)
IlkaIllers1
Quite often, I need to check the geoprocessing history of a feature class in order to see which original layer was used to create it. For this, I work with the INSPIRE Metadata Directive as the Metadata Style. In Pro, I set the same Metadata Style:
And activated "Write geoprocessing operations to dataset metadata":
But when I open the metadata, neither the geoprocessing history nor the other information I am used to see in the metadata is available:
Does it not carry over the geoprocessing history from geoprocessing done in ArcMap? Because that would be quite a desaster!
