Eastings and Northings Coordinates - comma thousands separator??
3112
12-14-2021 07:08 AM
Labels (2)
FraserB
I have a map layout which uses dynamic text to show the centre coordinate of the map frame as eastings and northings (BNG). Currently, it shows as 397727  292304. I know it is pedantic, but it is important that these coordinates show as 397,727 292,304, i.e. with a comma separator. I have looked and tried but I cannot see if there is a way to do it, so help would be appreciated. Thanks!
This is the mark-up language:
<dyn type="mapFrame" name="Map" property="center.x" units="" format ="standard" decimalPlaces="0"showDirections="false"/>, <dyn type="mapFrame" name="Map" property="center.y" units="" decimalPlaces="0"showDirections="false"/>
JayantaPoddar
Add the following tag to the dynamic text
separator="true"
e.g.
Center: <dyn type="mapFrame" name="Map Frame" property="center.x" units="" format ="standard" decimalPlaces="0" showDirections="false" separator="true"/>, <dyn type="mapFrame" name="Map Frame" property="center.y" units="" format ="standard" decimalPlaces="0" showDirections="false" separator="true"/>
Think Location
DanPatterson
MVP Esteemed Contributor
FraserB
Thanks for the reply, is using arcade the only way then? I would have though there is a setting somewhere that allows you to thousand-separate the coordinates? On the map properties for example. Or a way to add such a separation directly using a dynamic text tag?
JayantaPoddar
separator="true"
e.g.
Think Location
FraserB
Perfect just what I was after! THanks
