I’m using ARCGis Pro 2.2.2 connecting to Oracle 12.1.0.1.0 to enterprise Geodatabase 10.2 and I’m getting below error when I try to view Geodatabase connection properties .
Although I mange to connect to the geodatabase .
Jonathan, I should have clarified. All of my testing was done using Operating System Authentication (OSA).
Answers to your questions:
For our implementation, what we have found is that all of the errors are generated when "SDE" is selected as the schema geodatabase, which is the default when the Create Database Connection dialog. If we use the Create Database Connection geoprocessing tool and pre-set a schema other than "SDE", then TNSNAMES and LDAP works fine for seeing and changing Geodatabase Connection Properties. Oddly, Easy Connect still has issues.
What version of SDE are you using as you mention Enterprise Geodatabase 10.2?
Micheal.
we are using SDE 10.2.2 ... , is this can cause the problem ?
I don't think so as I get the same error when using SDE 10.5.1 with all applicable patches. I'm just thinking you might want to bring your SDE database up to a more current version as 10.2.x is getting dated at this point, but this is probably not a trivial task.
Is your org also using ArcMap? If so, what version are you using for ArcMap?
