Excel table error message
3794
7
06-24-2021 12:53 PM
AlysonStanton
I installed the Microsoft Access database engine 2016 - quiet install (determined had click-to-run 64bit) - downloaded the 64bit driver - it appears in Apps & features. Restarted ArcPro 2.8.1. Reconnected folder with excel table - the error message still appears.
JayantaPoddar
Did you execute the installation process using Command Prompt (Silent Install)?
Here is a nice blog to guide you through the process Guide to connecting to Excel files in ArcGIS Pro
Think Location
JayantaPoddar
Have you restarted your system after installing the drivers?Install the Microsoft Access Database Engine driver
Think Location
AlysonStanton
Yes - restarted - also did a complete shutdown.
JayantaPoddar
Think Location
AlysonStanton
Yes - did a silent (quiet) install using the cmd prompt - it is installed - shows in App&features - but still get error msg.
JayantaPoddar
Could you share what steps are you following, when you receive the error message?
What is the error message (Share screenshot)?
Think Location
AlysonStanton
when I click on an xlsx file - the Error: Required Microsoft driver is not installed appears. When it happened the first time I followed the steps to install the driver (see screen shot). I tried again and the error still appears. PC was shut down - folder was reconnected. I did find that if I saved the file as an xls file the error message did not appear and I was able to geocode the file. However; I find it strange that before upgrading to 2.8.1 I did not have any problems with xlsx files.
JayantaPoddar
Another workaround could be using Excel to Table.
Think Location
