Create Locator: ERROR 002777
8016
8
05-20-2021 11:17 PM
Labels (2)
StefanBrandt
I'm on AGP 2.7 trying to create a Locator using the Geocoding tool "Create Locator".
But no matter what name I put into the Output Locator field (even the default one I get when I first select the primary table) I only get
ERROR 002777 The name is invalid.
I tried using only letters, various forms of lower or upper case with or without numbers but I can't find a name that the tool will accept as valid.
Any help is appreciated.
JayantaPoddar
What's the full path of the output?
Please ensure there is no space, special characters or accented characters in any of the folders as well.
Think Location
JayantaPoddar
Think Location
tristan_goers_fnsb
I have the same issue. My path is...
C:\Users\tristan.goers\Documents\github-repositories\gis-agol-scripts\Toolbox\FNSBLocator
Where FNSBLocator is the locators name.
Michael_Rehberg
Is the no space/special/accent in the path a common requirement for all the Geoprocessing Tools?
JayantaPoddar
It's more of a naming convention for the GIS files. Many Geoprocessing tools may result in error if proper naming convention is not followed.
Here is a good article I found online. https://learngis.org/textbook/section-six-arcgis-file-naming-rules
Think Location
ZandBakhtiari1
I had this issue an it turns out it didn't like the network drive I was using.  I pointed it to my desktop and it worked fine.
JayantaPoddar
Also Desktop is not an ideal directory to store your GIS Data objects. You could save on a local drive within a Data/Project Folder (Not under Users folder).
Think Location
ZandBakhtiari1
I just did that to get the tool to work.  I moved it after that to the same network location and it works fine.
AllenDailey1
I have been having this problem, and I found this bug documentation from Esri:
https://support.esri.com/en-us/bug/create-locator-returns-the-error-message-error-002777-t-bug-00015...
My path does have periods in it, in the server name, which includes "name.dmz".  So I guess that's the problem.  The bug was found in Pro 3.0.2 and fixed in 3.1.  I am using 3.0.3.  Time to upgrade!
