Can you update an existing Project Template?
3274
03-12-2021 03:35 PM
Labels (2)
AbraKaiser
About 6 months ago I created various project templates for us to use. We now have some updated County imagery that I would like to add to these templates for future use. Is there a way to update an existing project template? When I open the template through the main start up screen, it wants me to create a new project (ie choose a place to save the project), but I don't want to create a new project to update the template if I don't have to.
by Anonymous User
Not applicable
Hi Abra.
Where are you storing and accessing your project templates? I assume they are in a centralised location where others have access to them? If you have them shared to Portal and you have the right level of user credentials (eg. publishing) you should be able to overwrite the template in Portal if your local template has the same name as the portal template. when you go to 'Share' to the same portal location as the existing template you will get a message saying there is an existing template at this location, and would you like to overwrite it.
Let me know if this works, or alternatively where abouts you are trying to overwrite an existing project template.
KevinStarr
I am having the same issue as Abra and cannot find any related threads providing a solution. How do I access my existing template to make changes without creating a whole new project?
MaisieBiles
I am also looking for an answer to this. I tried opening the archive within the template's 7-zip to extract the project from within and edit that but it didn't update the template saved within ArcGIS Pro. I would really prefer to not make a bunch of new templates so if anyone has a solution to this please send in any suggestions.
MatthewYoung1
I'm also seeking answers to this--posting here in case someone posts a solution.
