I have a hundreds of company logo png files that I am trying to batch import as point symbols. I haven't had much luck batch importing them to XY points (seems you have to do it individually...way too many for this).
However, could one geocode (associated XY coords) with the png files (via some software, or other) and then import them as point symbols?
Solved! Go to Solution.
The instructions are simple enough but it doesn't work for me. 2.9 or 3.1-2. Different APRX, different images, just get the broken image symbol, I just gave up
Johannes,
I put the code verbatim into the Python script window (found in analysis); but, how do I run it? I don't see a go, or run.
Change NameOfLogoLayer to the actual name of the logo layer (or the path to the feature class).
To run, skip to the end of the code and press enter.
Does the Python need to be activated?
Johannes: Sent you a direct message with attachment.
Johannes: Sent another attachment, with code--the code ran this time, but got an error. Screen capture is in private message. Again, many thanks.
Johannes: I have the URL of the logo in logo path--but what goes into logo data? I have nothing in that column--what should be there?
IT WORKED!!
