Can you import multiple geocoded png files as point symbols?
2349
18
11-17-2021 06:12 AM
DavidZiegler
I have a hundreds of company logo png files that I am trying to batch import as point symbols. I haven't had much luck batch importing them to XY points (seems you have to do it individually...way too many for this).
However, could one geocode (associated XY coords) with the png files (via some software, or other) and then  import them as point symbols?
JohannesLindner
MVP Frequent Contributor
@m3
  • It doesn't work with labels, only with symbology (but I guess you're actually using symbology)
  • It doesn't work with attachments. You have to read the byte data into the actual table.
Have a great day!
Johannes
m3
Occasional Contributor II
The instructions are simple enough but it doesn't work for me.  2.9 or 3.1-2. Different APRX, different images, just get the broken image symbol, I just gave up
DavidZiegler
Johannes,
I put the code verbatim into the Python script window (found in analysis); but, how do I run it? I don't see a go, or run.
JohannesLindner
Change NameOfLogoLayer to the actual name of the logo layer (or the path to the feature class).
To run, skip to the end of the code and press enter.
Have a great day!
Johannes
DavidZiegler
Does the Python need to be activated?
DavidZiegler
Johannes: Sent you a direct message with attachment.
DavidZiegler
Johannes: Sent another attachment, with code--the code ran this time, but got an error. Screen capture is in private message. Again, many thanks.
DavidZiegler
Johannes: I have the URL of the logo in logo path--but what goes into logo data? I have nothing in that column--what should be there?
DavidZiegler
IT WORKED!!
