Batch Assign Domain to Fields
2492
02-17-2022 07:37 AM
Labels (2)
JessicaJThompson
Hello! (ArcGIS Pro 2.9.1)
I am building a bunch of surveys for a department, and creating them from a feature service in Survey123 Connect.
The Issue:
For a number of the fields of the feature class (to become feature service hosted by portal), the same domain is applied. To for a few hundred fields I have many of the same 3 domains. Is there a way to do a Batch Assign Domain to Fields?
Thank you for your help!
Cheers,
Jessica
RhettZufelt
MVP Notable Contributor
Have you looked at running the Assign Domain to Field GP tool in batch mode?
Batch geoprocessing
Or, maybe run a small batch, copy the python and modify for your needs.
R_
RhettZufelt
Batch geoprocessing
R_
JessicaJThompson
@RhettZufelt Thank you! I knew there was a way!! I had yet to do any Batch geoprocessing in Pro, and I wasn't finding the right search terms for some reason.
Much Appreciated!
Jessica
