Assigning elevation to a contour shapefile
2832
6
06-01-2021 06:15 AM
JasonShim
I have a digitized contour shapefile (polygon) that I'm trying to assign an elevation. The contour line was traced from a construction drawing (.jpeg) that I have imported into ArcGIS.
I tried using the edit z-value feature tool but that didn’t work for me. I wasn’t able to assign an elevation to it. Elevation is still showing as zero. I have attached a screenshot of my contour shapefile and inputs in Create Feature Class and Edit Vertices. Just wondering if there’s something that I’ve done incorrectly? Can someone advise me on this?
Thank you,
Jason
DanPatterson
MVP Esteemed Contributor
In a pinch, since I suspect you created a 2D featureclass, why not add a double field called Elev or Z_val and add the value of the contour there.  At least you can use what you have done for most work (like labeling etc etc)
... sort of retired...
JasonShim
Hi Dan,
Would you be able to demonstrate this "double-field" in a screenshot as an example? Where can I find this "double-field" feature? Sorry, I'm very new to ArcGIS.
Jason
DrVSSKiran
At first, right-click on your contour polygon in the table of content and go to the attribute table. Create one attribute field either integer or float. and go to the start edition and assign the attribute value in the created attribute field.
Thanks.
DanPatterson
@JasonShim
help topics are best, and ArcToolbox is your best friend if you a new to Pro.
Everything else is a shortcut.
Add Field (Data Management)—ArcGIS Pro | Documentation
All arctoolbox functionality begins here
Anatomy of a tool reference page—ArcGIS Pro | Documentation
see the table of contents to the left of that page...
Other readings and tutorials
ArcGIS Pro quick-start tutorials—ArcGIS Pro | Documentation
for example
Manage data—ArcGIS Pro | Documentation
JasonShim
Dan, Thank you very much for the helpful information.
DanPatterson
Have fun and good luck on your gis ventures
