Are we able to save absolute paths yet?
1732
04-22-2025 08:56 AM
ColbySmith3
I see posts from a handful of years ago asking for the option to save absolute paths in a Pro project, but I'm still not finding if it has been implemented. Is there a way to do this? Or have they still not implemented it?
DanPatterson
MVP Esteemed Contributor
What object are you trying to save that is giving you issue?
A "project"? or something else?
... sort of retired...
ColbySmith3
There are times when I want to move my project to a different folder on the same drive. The map data it references is in a folder that doesn't move. If I move the project the links change because they are relative to the project. Being able to toggle between saving relative data paths and absolute data paths used to be a thing in ArcMap, but I'm wondering if that exists (or ever will exist) in Pro.
DanPatterson
simply Package your project as if you were going to share it externally
Package Project (Data Management)—ArcGIS Pro | Documentation
delete your history and any extraneous caches before to get a clean output
