ArcGIS Pro - Symbology Tab How to turn off <all other values>
5890
6
07-11-2018 09:01 AM
ChrisWest2
In ArcGIS Desktop 10, in the symbology for a layer in the map, for the  "<all other values>", there is a check box that can be unchecked so that the  "<all other values>" do not display in the map, see the following snapshot,
ArcGIS Desktop 10 All Other Values
However, in ArcGIS Pro 2.1.3, For the "<all other values>" , there is no checkbox to turn off their display in the map, and on the right click menu, the "Remove" menu entry is grayed out, see the following snapshot:
ArcGIS Pro All Other Values
Is there a way in ArcGIS to turn off the display of the "<all other values>" in the map, similar to how they can be turned off in ArcGIS Desktop 10?
DanPatterson_Retired
It is there... you just have to find the toggle off option
MichaelVolz
Esteemed Contributor
Talk about simplifying the software.
My Rules...
Left click
Right click
Double click
If they don't work... you are clicking on the wrong thing
First lecture material for GIS courses
ChrisWest2
Dan,
Thank you for detailing out the steps needed to turn off the "all other values".  I just missed it when I was trying to find it.
Chris
KoryKramer
Esri Community Moderator
Dan's rules are spot on  If you right-click on <all other values> you can just remove it.
I went back and read your original question.  You're on 2.1.3.
This was updated in 2.2.
JimUzel
Funny that my 2.1.3 looks different. But thanks for this post - it helped me "find" the check-uncheck option in my install.
